Offset fine tuning
ski spiggy
Offset fine tuning
Post by ski spiggy »
Hi all.
I have a problem with the hardware setup offset fine tuning.
My sample offset is 8136 samples for the round loop when recording audio.
But last week, when using parallel outboard drum compression, the audio was in time/phase when I was using it just on the input(live), but when I printed it, the phase was off. So I checked the alignment and it was out by 30 samples.
I thought that's odd. So I corrected the error in "fine tuning" by subtracting 30 samples in the record window.
Problem solved. But later that day the same thing happened. This was because the "fine tuning" was not needed. And the 30 samples over compensated.
Crazy.
Any help would be greatly appreciated.
Spig
Mac Pro 5.1 12 core 3.46ghz. 24 gig ram. OS 10.11.6. DP 8. Soundtoys, Waves api. Vallhalla Room.
