On the two projects I've tried that were started with Omnisphere 2.5, that use the arpeggiator, I've found the arpeggiators are messed up since installing 2.6 - lagging, not playing the correct pattern. One of sequences would intermittently beachball and stall when I hit Play.
The fix, so far, is to save the Multi in Omnisphere, remove and replace the instance and reload the saved Multi.
I'm curious if anyone else is experiencing this. I'm debating whether I should report it to Spectrasonics or MOTU.
Omnisphere 2.6 weirdness
