DP 10 and Mach5(3) issues?
I use MachFive a lot, and it's my go to for most VI needs.
Since installing DP 10, I occasionally get an error that some samples can't be found and an instrument will load but not be playable. If I close the project and reopen it, all is fine again. This seems more consistent with the True Keys pianos than with other instruments.
I did not d/load the 5GB of M5 sounds that MOTU have provided with the update as they are duplicates of what I already have.
Re: DP 10 and Mach5(3) issues?
Try a safe boot, then reboot normally.
Thanks, Mike. I should've thought of that!
