Mix indiv tracks in EWQLSO Gold in DP?
timware99
Post by timware99 »
I'm using DP 4.2 (OS 10.3.9) and have the MachFive and the EWQL Symphonic Orchestra Gold working fine. Except, using the DP mixing board, I can control the parameters of the MachFive tracks individually, but not the ESQLSO Gold tracks - the faders, pans etc work with the instrument track for the ESQLSO but not the individual tracks. The MachFive isn't having this problem.
The instrument tracks for both M5 and ESQLSO outputs to Analog 1-2, which is the output for all tracks. The individual tracks for both samplers have the Radium as the input and the sampler as the output. Perhaps there's a setting for the ESQLSO that I'm missing?
Thanks.
Tim
Tim Ware
iMac Pro (2017) - 3.2 GHz 8-core Xenon W - 32GB - DP 11.34 - Latest Mac OS
dtobocman
Post by dtobocman »
There is a switch you can turn on in the "settings" menu within EWQLSO that allows the plugin to read #7 and #10 controllers. Engage this switch and your problems will be solved.
timware99
Post by timware99 »
Thanks, my friend. It worked like a charm!
Tim
Tim Ware
