New presonus Faderport
Posted: Thu Jul 19, 2018 8:43 am
by bjornln
Hi,
You have probably seen this before.
But if not...there seems to be a new version out. 199$
https://www.presonus.com/products/FaderPort
/B
Re: New presonus Faderport
Posted: Sat Jul 21, 2018 7:56 pm
by Rick Cornish
I like the one I have. DP integration is a little limited, but it does what I need. I only wish it had a track name readout like AlphaTrack.
Posted: Mon Jul 23, 2018 12:26 pm
by waxman
Is the new one compatible with DP?
Posted: Mon Jul 23, 2018 12:59 pm
by Rick Cornish
waxman wrote:Is the new one compatible with DP?
Yes, but I would contact Presonus for details.
Posted: Mon Jul 23, 2018 1:20 pm
by EMRR
Hmm, have to keep an eye on this, thanks.
Posted: Sat Oct 03, 2020 5:54 pm
by Sedaray
I bought one. Got DP 9.5.2 to recognize it in two ways in the Control Surface setup; but it doesn't do anything in DP.
Presonus forum says DP is not recognized in 64bit and gives no more help.
Sending it back.
Posted: Mon Oct 05, 2020 5:00 pm
by MartinBaird
PreSonus FaderPort has been tested and approved to work with the following software:
Native Mode
PreSonus Studio One® 3.5.6 with extension*** or Studio One 4.0.1 or later
HUI Emulation
Supported by Pro Tools
Mackie Universal Control Emulation**
Supported by Logic, Cubase, Nuendo, and Ableton
** Users of third-party DAWs not listed that support the Mackie Control protocol, such as Reason, Bitwig Studio, and Reaper, should contact their DAW vendor for support.
Posted: Thu Jul 29, 2021 6:59 pm
by daveyboy
Is anyone using the “new” Faderport in DP successfully? My Alphatrack currently doesn’t work in DP11 (still works in 10) and the older Faderport is sketchy. I don’t mind getting the newer Faderport if indeed it actually works.
Posted: Wed Nov 10, 2021 8:30 am
by shelly_the_turtle
Just figured out how to get my older Faderport to work in DP 11. Go to Setup => Control Surface Setup. Set the Driver to HUI, and Track Filtering to Pin to Focus Window. Input Port to FaderPort-1, Output Port to FaderPort. PIN TO FOCUS WINDOW was the real fix here... it was default set to Pin to Mixer when I switch to 11 from 10. Hope this works for you too, and perhaps try the same method for your Alphatrack!
Cheers!
