I'm on Sierra and DP 9.51 and can't get Apptrigga to show up any longer. Not sure if anyone else is able to use it. May have to find another drum sample replacement tool.
Anyone able to get it to work?
Apptrigga: Is it dead and gone?
Fibes
"You can like it, or not like it."
DP 7.24, 12 Core 2.66, Reason, Live, UAD-2 full meal deal, Sonalksis 315 & 517, DUY Everpack, Altiverb 6, Apptrigga, Autotune 5, OHM Force Experience, Audio Damage Dishord/Adverb/Dubstation, PSP full meal deal, Camelphat/Space, Wave Arts Power pack and many more.
Re: Apptrigga: Is it dead and gone?
What does apulSoft say?
- FMiguelez
Have you tried DP's trigger?
I have heard nothing from Apulsoft.
Fibes
http://www.apulsoft.ch/aptrigga3/index.php
the V2 of this plugin was 32 bit only, DP 9.5.1 needs 64 bit. I have used the V2 wrapped by 32 Lives for backward compatibility on old project brought forward and it's fine minus having to relink the original samples occasionally.
I've used the V3 64 bit version of this for a while and I feel like it triggers as well as Slate does, just without the massive library of sounds. Thankfully I have gigs of samples from project going back 20 years! It tracks flams pretty well, and that's my measuring stick. Sometimes it's just the right thing, and isn't as big of a pull on the CPU as Slate Trigger. Also, the under snare samples are awesome on live shows I get with no bottom snare mic, or with so much buzz from a slamming drum wedge, it's more easy to recreate than to try and gate or cut it out.
I have apptrigga 3 and it doesn't even show up after install.
So weird.
So weird.
Fibes
