This is a feature request/criticism/comparison for DP...
When I'm selecting input and output settings in a DAW, I normally think of the Mixer screen as the place to do that. But if you want to change the outputs of a bunch of channels at once, you can't Edit/Select All from the mixer screen, you have to be on the Tracks or Sequence window. (and then use option-A to bring up the Track Assignments window.)
In Pro Tools, when you select a track in the Edit window, it is selected and highlighted the same way in the Mixer window. I wish DP did the same.
(If memory serves, in some early versions of DP--DP5? when you were in the mixer window and pressed Option when changing the output of a track, all tracks would assign to that output.)
Selecting tracks on the Mixer screen
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
Re: Selecting tracks on the Mixer screen
Yeah, I've long hoped for the ability to select channels too, mate.
