Definitely a 'PreGen' mode problem
artfarm1
Post by artfarm1 »
I've just posted, and then Updated, my recent post of 'From DP 9.12 back to 9.02'
Things were working great, until I quit DP and then came back to it and opened up the same project.
Upon re-opening, I had audio artifacts problems. The plugins were in 'PreGen' mode.
If I get them to run in 'RealTime' mode, then all is well again.
Maybe when I first opened up my new 9.02 and imported my project, they initially loaded in 'RealTime' mode?....because all was beautiful.
Anyways, now all is fine when I run the plugins in 'RealTime' mode on my system and 9.02. (...or in DP 8.07 too!)
And, with 9.12, the audio artifacts are still happening whether I use 'PreGen' or 'RealTime' mode. Makes no difference. Have to go and use 9.02 on my system.
Update over for now....
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
Re: Definitely a 'PreGen' mode problem
This belongs in the Troubleshooting / Criticism forum.
artfarm1
Post by artfarm1 »
Yes, will repost any other tech things like this is the other forum.
DP 11, OS Ventura
artfarm1 wrote:Yes, will repost any other tech things like this is the other forum.
Thanks. I moved it. I was away from my computer earlier and using Tapatalk, so I mostly replied so that I could find this topic later in order to move it the the appropriate forum. :)
