DP 9.2 and Kontakt delays inconsistently 1/2 beat ...
- Timeline
Anyone solve this? What version ok Kontakt five fixes this?
Re: DP 9.2 and Kontakt delays inconsistently 1/2 beat ...
Your question is unclear. What do you
mean by "delays inconsistently 1/2 beat"?
What version of Kontakt are you using?
Is this happening with just one instance of it?
Also..you mean DP 9.12, yes? There is no
DP 9.2.
DP 9.2.
http://www.davepolich.com
- Timeline
Yes 9.12 sorry. I was a bit frustrated when I posted that. I had three instances and all suddenly after being spot on started to delay audio. I endured and moved the files and thats where I am currently.
I finished the mix however and sent it on.
5.5.2.880 version of NI Kontakt
Komplete Control 1.6.2.5
OSX 10.11.6
Dual 6 core core 3.46 48GB ram
Thanks David
OSX 10.11.6
Thanks David
Could be a automatic delay compensation issue, possibly after adding a look-ahead limiter to your project. Did you try a re-start and, if so, did the problem persist?Timeline wrote:Yes 9.12 sorry. I was a bit frustrated when I posted that. I had three instances and all suddenly after being spot on started to delay audio. I endured and moved the files and thats where I am currently.
OSX 10.11.6
Thanks David
- Timeline
Yes it works fine for a while after reload and just jumps to the delayed audio. I think your on to it though. These were imported songs 3 or 4 years old being remixed for an album
