Hi folks. Newbie here. I am running DP8 with core audio on a Mac mini (late 2012) recently updated to El Capitan. I have 16 GB, and use 24 bits with DP8.
Everything worked smoothly for several weeks. Suddenly DP8 no longer accesses core audio for input. Ok with output. Other DAWs are working perfectly. I re-installed DP8. Same problem. I use core audio as opposed to another audio system because what I create gets redone in a professional digital studio environment.
Is there a recent core audio driver for DP8 with El Capitan? What I found didn't mention DP8.
I am not tech sophisticated, just doggedly determined. Any thoughts? Your help is much appreciated!
DP8 Core Audio problems with El Capitan
Re: DP8 Core Audio problems with El Capitan
Just to double check that you've set this up...
Setup menu/Configure Audio System.../configure hardware driver.../
You might need to set up the chosen device in AudioMIDI setup to make sure everything is good there. Double check sample rates, etc.
Not sure what else. I do know that sometimes DP will auto-select the AirPlay device when it doesn't have a preference file.
Good luck.
Good luck.
I do most of my work in CoreAudio, switching to my MOTU interface only when tracking in the studio.
Go through the setup to make certain it is correct. It's easy to hit something accidentally that changes everything.
I had a weird CoreAudio issue of my own. About a month ago, I opened my test project—I keep one that I use to check new features, bugs, problems, plugin demos etc. I noticed that the panning was reversed. ??? It wasn't DP. I knew that so I wondered if my new Radial monitor controller was wired backwards. I plugged in my old Behringer and it was the same... What the?
I went through everything and CoreAudio output was reversed. Not finding the problem even after unplugging, resetting the NV RAM and rebooting, I gave up and reversed the output in System Preferences. OK... moving on.
Then a few days ago, I was listening to a live Who track and heard John Entwhistle's bass coming out of the left speaker. Huh?!?!?!? CoreAudio had reset. I went back into System Preferences/Sound and restored the output to the defaults.
The only thing I can think of is that I had updated Logic Pro X to 10.2.1 before the reverse happened and MainStage to its current version last weekend. Could that have caused this? I have no idea but can't think of anything else. So, problem solved—or is it?
Hi folks. I'm experiencing intermittent problems still with DP8 seeing Core Audio. For a while everything ran smoothly. Suddenly without my doing anything I can think of, DP8 stopped it. I'm running El Capitan 10.11.4 on a Mac Mini (Late 2012) 2.5 Ghz with 10GB memory. The problem occurs no matter how little or much memory I install. I have run through the Set Up with both high and low buffer sizes. I have configured everything to 32 bit float. Interestingly, I am having the same problem with another program Ableton Live which I rarely use. However, I have no problem with a simple program - NCH's Mixpad. Works perfectly for it!
Can the problem be with El Capitan? Don't see any drivers related to this.
I'm bewildered! Any further thoughts from this community are greatly appreciated. Have been using DP since DP2(!!) and this is the first time I've encountered such a strange situation.
Thanks folks.
tunemeister
Thanks folks.
tunemeister
There are no CoreAudio drivers—when something is compliant, it means you don't have to install drivers. There's the Mac OS. No issues with CoreAudio that I know of.
There are programs that can mess with it but they all come from Apple. Besides the OS, there's Logic, MainStage and iTunes. My weirdness corresponded with a Logic update and went back to normal with a MainStage update. Even then, DP has had no problems with it.
You probably need to go through your setup with MOTU. There are many settings that can affect the way that DP behaves. You haven't described your setup nor the specific problem.
I would take a look at the manual and see if the Solo function behaves the way you think it should. Depending what is highlighted, this can really mess up your outputs if you accidently click on the wrong button.
