motu tuner plugin included with DP
theodour
Post by theodour »
I'm trying to use the built-in tuner plugin but can't get it to do anything. My inputs are set correctly and I can successfully record to the track, but if I put the tuner plugin on it, it doesn't seem to be listening to my input (guitar). Do I need to set an input specifically within the plugin?
note: I would use the cuemix tuner, but I have the original traveler which doesn't support this.
cleamon
Re: motu tuner plugin included with DP
Post by cleamon »
theodour wrote:I'm trying to use the built-in tuner plugin but can't get it to do anything. My inputs are set correctly and I can successfully record to the track, but if I put the tuner plugin on it, it doesn't seem to be listening to my input (guitar). Do I need to set an input specifically within the plugin?
You may need to check the input button on the channel in the mixer (it's under solo/mute/rec).
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Klaus
Post by Klaus »
Have you tried with an aux track ?
Best
Klaus
Setup> Configure Audio System> Input Monitoring Mode>Monitor Record Enabled Tracks through Effects.
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
theodour
Post by theodour »
cuttime wrote:Setup> Configure Audio System> Input Monitoring Mode>Monitor Record Enabled Tracks through Effects.
Yes! Thank you so much!
