Just switched from Logic Film Scoring to DP
Digital Perfomer in the context of television/film scoring and post-production.
a82music
Post by a82music »
I've switched from Logic to DP for film scoring, so I'm trying to learn the basics right now.
I'm scoring a very short (10 minute) animated student film. I've already spotted the video, so I have my cue sheet in front of me (list of cues each with a start/end time). I have a total of 6 cues.
I want to create markers for the beginning and ending of each cue, correct?
How do you set markers aligned perfectly to a particular frame (NOT the "Record Hits" feature which I understand is real-time)?
Re: Film Scoring in DP
Set the playback bar (whatever that's called...) and do your thing.
a82music
Re: Just switched from Logic Film Scoring to DP
Post by a82music »
OK, I have the playback bar at the exact frame where I want to insert the first marker, so I drag the yellow marker icon over but it snaps to the first beat of the closest measure. That's the problem; it's not going to correct location in the measure.
RROY
Post by RROY »
Hold down Command button while dragging marker, it'll go wherever you want.
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
Better yet, hit cmd-m. Check the Commands window and change to key command (search for markers) to add options. You can add the marker and name it in one step.
Lulu_German
Post by Lulu_German »
Watch a tutorial on YouTube.
djwizprod
Post by djwizprod »
Guys, more simply, open the markers window, and click add marker from the mini menu, marker is dropped precisely where the transport play bar sits.
MacPro8core28GB~OS108.5~DP9.1
PT10~MACH5~Symphonic~Reason~Symphobia~NIKOMPLETE~StormDrum2+3~EWSilver
MiniCore2duo2GB~VirtualVTR~TASCAMDM4800surround~2408MkIII~WAVESBroadcast/Surround360/NPP/VoxRider/GEQ/L316~UAD2DuoPCIe+Satellite~1176/LA2A/PulteqPro/Fairchild/SSLBuss/Lexicon224/Dreamverb
IzotopeRX5/Ozone7/StutterEdit
UA6176~U87~TLM103~AKG414~MKH416~MKH50~DPA4011Apair/COS11D~QuickTime7Pro/FinalCutProX/MackieHR824/624/HRS120~TelosZephyrXstreamISDN~SourceConnectPro
http://www.ozonesound.com
bralston
Post by bralston »
Learning the Key command short cut for adding a marker is your friend here. It add where the wiper is
Regards,
Brian Ralston
bralston wrote:Learning the Key command short cut for adding a marker is your friend here. It add where the wiper is
And you don't have to f@#$ with the damn mouse or trackpad.
