good Mac repair/troublehshooting forums?
williemyers
Post by williemyers »
hey all, aside from (perhaps) Macrumors.com, which Mac repair forums do you find to be knowledgeable and helpful?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
Re: good Mac repair/troublehshooting forums?
MacOSHints was the only one I found consistently useful, but it is no longer active.
williemyers
bayswater wrote:MacOSHints was the only one I found consistently useful, but it is no longer active.
UGH!! (but thanks :) )
~me
Google Searches, then distill into a semi-reliable tonic.
The best Mac forum I know of is a sub-forum right here at da 'Nation.
It's called mikehalloran:
http://www.motunation.com/forum/memberl ... le&u=42518
artfarm1
Post by artfarm1 »
Yeah.... I've probably more about my Mac over the last 15 years from right here on Motunation!!
Thanks to all!
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
Dare I ask what's wrong?
A sub-forum intelligent enough even to ask a question?
Crikey, what'll they think of next?
Gravity Jim
Post by Gravity Jim »
Apple's own forums have been a good source for me.
Jim Bordner
williemyers
mikehalloran wrote:Dare I ask what's wrong?
short version is (was!) that an older MBP with a new SSD (running 10.10.3) died. I purchased a newer MBP, thinking I'd just slap the SSD in it and off I'd go!
After putting it in the newer MBP, it wouldn't boot and would give me a slashed circle. Neither I not the supplier of the MBP had any ideas and then, after a week, I stumbled on to *this* (which turned out to be the solution!):
https://www.cindori.org/trim-enabler-and-yosemite/
~me
There's a sticky on this in case you do it again. It's more up to date than the Cindori web site and gives you some options:
http://www.motunation.com/forum/viewtop ... =4&t=59419
williemyers
mikehalloran wrote:There's a sticky on this in case you do it again.
thanks for that, Mike...
~me
Hey, when it comes to screwing up, some of us are bleeding edge! :headbang:
The trick is to learn from it and post the results.
