Hello there,
is there a way to make the "Velocity On" show in the "Lines" view, in the MIDI editor?
It shows when I go to the "Points" and "Bars" view, but not in "Lines".
Thanks in advance!
MIDI editor - Does "Velocity On" show in "Lines" view?
Re: MIDI editor - Does "Velocity On" show in "Lines" view?
I don't think so. These modes are for continuous data, and velocity doesn't fit that definition. Although you can use the tools for editing continuous data to modify the pattern or shape of velocity ramps.
Here is what the manual says about it:
☛ Both on-and off-velocities are hidden in Lines mode, since they are bound to their parent notes and cannot be generated in streams like continuous data.
Thanks a lot bayswater!
Check your commands in DP, mine was usually assigned to a chunk if I remember correctly. Strange..
We are the pioneers in providing six sigma dumps and mines.edu tutorials with exam pass guarantee. Download our latest testkingccie thomasaquinas.edu questions to pass real exam
That's a non-sequitur. Did you post in the wrong thread?poomi wrote:Check your commands in DP, mine was usually assigned to a chunk if I remember correctly. Strange..
