Audio Wire
Posted: Fri Feb 27, 2015 9:36 am
by larbok
Hi,
Is there any difference between the Audio wire used on the 2408Mk2 and the 2408Mk3?
Thanks you!
Re: Audio Wire
Posted: Fri Feb 27, 2015 12:18 pm
by mikehalloran
If you are trying to make a FW-400 cable work or are trying to figure out which cable in the box is the AudioWire, this may help.
The original AW cable has a slightly different connector than a FireWire cable. Peeling back the insulation on a FW connector about 3/16" generally works. Use an Xacto knife, single edged razor blade or similar tool.
I have only owned a 1st gen 2408 -- these predate FireWire, BTW. If MOTU changed connectors on the later versions so that an FW cable just works, I have never heard.
Re: Audio Wire
Posted: Fri Feb 27, 2015 9:15 pm
by monkey man
All AudioWire cables are the same; I've used the system since the 2408mkI and there's been no change AFAICT.
Re: Audio Wire
Posted: Mon Mar 02, 2015 2:03 am
by JeffB
I've always used firewire cables with no problems.
Re: Audio Wire
Posted: Mon Mar 02, 2015 8:25 am
by mikehalloran
JeffB wrote:I've always used firewire cables with no problems.
That works for many. For others, it doesn't work without modification of the connectors.
