Hi,
Is there any difference between the Audio wire used on the 2408Mk2 and the 2408Mk3?
Thanks you!
Audio Wire
Audio Wire
LARRY BROCKWAY
HALL OF FAME STUDIO
Mac Pro Quad 2.8 w/8gb Ram
IZ Radar 24
DP 8.1
Motu 2408 Mk3
Motu 2408 Mk2
MIDI Timepiece AV
Motu MIDI Express XT
Soundcraft 6000 52x24x2
HALL OF FAME STUDIO
IZ Radar 24
DP 8.1
Motu 2408 Mk3
Motu 2408 Mk2
MIDI Timepiece AV
Re: Audio Wire
If you are trying to make a FW-400 cable work or are trying to figure out which cable in the box is the AudioWire, this may help.
The original AW cable has a slightly different connector than a FireWire cable. Peeling back the insulation on a FW connector about 3/16" generally works. Use an Xacto knife, single edged razor blade or similar tool.
I have only owned a 1st gen 2408 -- these predate FireWire, BTW. If MOTU changed connectors on the later versions so that an FW cable just works, I have never heard.
Re: Audio Wire
All AudioWire cables are the same; I've used the system since the 2408mkI and there's been no change AFAICT.
Re: Audio Wire
I've always used firewire cables with no problems.
Studio: i7 4770K, 32Gb DDR3, W8.1 x64, PCIe424, 2408Mk3.
Stage: Lenovo W530 i7 3720QM, 16Gb DDR3, W7 x64.VS700R.
Re: Audio Wire
That works for many. For others, it doesn't work without modification of the connectors.JeffB wrote:I've always used firewire cables with no problems.
