Removing Unwanted Effects
adinboy
Post by adinboy »
I am using Digital Performer, I inserted a plug-in effect from the mixing board then tried to adjust it in the sequence window. I didn't like it so I deleted it but I am noticing these dotted lines and the drop-down says missing. Below is a picture of what I'm talking about squared in red:
How do I get rid of the dotted lines?
SMS
Re: Removing Unwanted Effects
Post by SMS »
First off, it seems this post should be under general use, not user showcase.
To answer your question, those lines are automation data for the (now deleted) pug-ins. If you select one of those items from the menu you've highlighted, it becomes editable and eraseable in the sequence editor.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
SMS wrote:First off, it seems this post should be under general use, not user showcase.
Indeed. Moved.
