Selecting multiple faders in DP8
jblen
Post by jblen »
Is it possible to select multiple faders in DP8 as in Logic where you just drag over the faders you want in the mix window?
Can't find any reference to this in the manual.
JBlen
Tritonemusic
Re: Selecting multiple faders in DP8
Post by Tritonemusic »
You can Shift-Click on the faders you want and they will blink green. After you make a move, they will stop blinking. Hope that makes sense. Just try it and see if that works for you.
DP 10.13, OS 13.7.5, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
Tritonemusic
By the way, you can do the same with the pan controls, too. I've never personally had a use for that, but thought I'd throw it out there, just in case you'd find it helpful.
