I Just bought the MTP AV USB to use on OSX.
Previouly, I use the old MTP AV Serial w/ Keyspan USB-serial adapter on my G4 OS9 work fine.
Now I want to use both together. However, I never get this 2 MTP AV work together.
The setup
MTP AV USB: Box 1-8 net port = mtp
MTP AV Serial: Box 9-16 net port = mtp
Connected the serial cable From net port to Net port
in OS9 FreeMidi onlt can see the MTP AV USB
in OSX AudioMidi setup only can see the MTP AV USB
What's wrong?
Can anybody tell me?
<small>[ April 05, 2005, 10:43 AM: Message edited by: vincenzo ]</small>
2 MTP AV Connect
2 MTP AV Connect
Vincenzo
Soundtrack, Mastering, Re-recording, Movie editing, Sound design
G4 1.25G DP/1.75G Ram/ 80G + 60G HD/ 120G x2 External HD/ Digi001/ D8B + Mackie 24.8/ M5000 8 AES I/O /Genelec 8040/.......
- buzzsmith
Re: 2 MTP AV Connect
Vincenzo...
I'm running the same MPT AV-MTP network that you are.
In OSX, in the Audio-MIDI Setup you will only see 1 device but it should have 16 ins and outs-obviously 9-16 is your networked serial MTP.
I recall that in OS9/DP 3.11 in FreeMidi setup, I would only see 1 MTP but it, too, had 16 ins and outs. (1-8 MTP AV, 9-16 MTP)
Does this help?
Does this help?
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
