Hello people, new member here,
I'm trying to use a GeeThree Stealth serial port. I searched the messages first, but couldn't really find anything pertaining to this problem. Maybe some of you using this have seen something like it.
Mac OS X 10.3.9, Quicksilver Dual 800,
Opcode Studio 5 LX
DP 4.6 (just installed yesterday)
I've installed the GeeThree Stealth Driver and MIDI Setup, told it to use the Stealth MIDI Port, configured it for a 15 port MIDI interface at 1MHz, etc. The 15 port Interface shows up in the Audio MIDI Setup.
I have a separate OS 9.2.2 Classic folder created for this, and I have already booted in OS 9, and made the OMS Setup document with everything set to "Emulate MIDI Time Piece".
The weird part is I had this working for a moment yesterday (it seemed). Now, however, the ins and outs in the Audio MIDI Setup are "confused". In other words, if I do "Test Setup", and click on Output 15, MIDI comes out of output 1. Click on Output 13, and MIDI comes out of output 9.
And none of the MIDI Inputs work.
I've been going crazy trying to find something that would affect this, but no luck so far.
<small>[ July 23, 2005, 05:04 PM: Message edited by: karmagician ]</small>
"Confused" MIDI Ins/Outs with Stealth Serial P
Re: "Confused" MIDI Ins/Outs with Stealth Serial P
That might be your problem. Still having the problem? I use the G3 stealth no problem. No quite sure about the Opcode interface thoughOriginally posted by karmagician:
T
<small>[ July 25, 2005, 07:53 PM: Message edited by: Tonio ]</small>
Actually, I went back and forth between OS X and OS 9, opening OMS, opening Audio MIDI, playing with settings, creating new setups, etc. - and now it works. I don't even know for sure what I did.
