cuemix pc output to spdif (828)
professor quack
Post by professor quack »
I'd like to send my pc output to the spdif out to sample on mpc.
normally I have PC sent to my monitors. I figure I could do this with cuemix but it doesn't offer the PC as an input. the PC can only be set to output directly to an output in windows (not cuemix)is this the case? If that's the case I figure I could plug an output back into and input on my 828 but it seems like a wasted input. leme know eggsperts thx!!!
edited. This is windows WDM output ie from youtube or something not an ASIO app.
Re: cuemix pc output to spdif (828)
Can't you use the equivalent of the Mac app MOTU Audio Setup to set the default main output to SPDIF?
professor quack
How can I hear what I'm sampling? I've resorted to putting an output back to an input and routing all pc sound to that output and routing that input to main. thx!
You can use the Return Assign to route any output back in to the computer without cabling. From there you can route the signal to whatever your main monitor outputs are. See manual p7.
