MOTU 8Pre's PSU fixing unidentified regulator
kaapula
Post by kaapula »
Hello Motunation, I'm new on this forum so I'm sorry if this is not the right area for this question.
I just bought a broken MOTU 8Pre Firewire. It has a 110V-230V autoswitching power supply. I opened the chassis and noticed there is a "U2" regulator (or atleast I think it's a regulator) blew to pieces and I'm quite positive that when I change this regulator to a new one, this interface will become back alive.
The problem is that I can't tell the type of the regulator, because it's so in bad shape and there's not any visible text anymore. The only print is in the PCB that says "U2".
I would appreciate if someone could open up their 8Pre and take a look at the regulator and tell me the type of it.
I've attached few photos of the regulator and the PSU itself.
Thank you!
EMRR
Re: MOTU 8Pre's PSU fixing unidentified regulator
Post by EMRR »
Good luck with it, I hope someone can get you the information. I don't know if MOTU would be of any help here or not.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
kaapula
Post by kaapula »
Thanks. Actually it seems that I hurried too much again. I found the missing pieces from the chassis by shaking it, and got the correct type. It is "CM0765R"
I just ordered it from eBay for $4 including shipping. It will take about 1-2 weeks to arrive. I will let you know about the process when I've got the item.
