DC here!
I have a recurring problem with windows setup.
HP Elitebook 8440 with Windows 8.1 Enterprise swedish all patched.
6Gb ram, 120Gb Intel SSD. External Seagate 500Gb 7200 rpm usb2.
DP-8.0.5 Motu Microbook + Wavearts plugins.
Several times every session for no reason I can spot I get the
following error:
"The audio hardware state changed while MAS was starting up"
(MotuAudioSystem Mas [59:0])
After this DP freezes and I have to force reboot of DP.
Any hints tips would be very welcome.
Cheers: Dixiechicken
MAS audio engine error
- dixiechicken
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
Re: MAS audio engine error
Just a shot in the dark - is your system/Windows audio or any other app running in the background configured to use the MOTU Microbook? Maybe something getting in the way there. IMHO, the ASIO implementation needs a little tweaking. I have been using ASIO4ALL with success to get around a couple of issues, but in your case you'd lose the hardware monitoring you get with DP + MOTU hardware. Also, DP 8.06 is available for the PC.
DP8.06 PT11.2.0 VEP 5.3.x
- dixiechicken
DC here!
DP uses the Microbook II ASIO driver.
If there is somthing else interfering... quite possibly.
I'll check further.
Will try downloading & installing 8.06 and see what happens.
Cheers: Dixiecken!
I'll check further.
Cheers: Dixiecken!
