DP 8 64 bit Mas plugins don't show up 32 bit Plugins Do
Swine
Post by Swine »
Having problem in DP 8.06 - 64 bit MAS plugins don't show up in plugin window. The only one there is invert phase. It's not a problem in 32 bit mode only 64 bit mode. I've dumped my preferences already to no resolve. Not sure why 64 bit MAS plugins don't work with their own program ? It's a full copy not a demo of DP8 do I need to uninstall reinstall ? Do I reinstall 64 bit version overtop as overlay reinstall / repair ? Also I'm on a Win 7 Rig and not new to DP I've been using it since 2.7 so I'm kind of a little stumped by this seemingly small issue.
Swine
Re: DP 8 64 bit Mas plugins don't show up 32 bit Plugins Do
Post by Swine »
Really no reply's at all ? Not sure if I should be Honored or Terrified. Nah I'm Just Messing with you.
I figured this might happen though . Silence ... Crickets chirping . It seems to have Motu a little stumped also because they haven't been able to HELP ME FIX IT yet either. I'll keep you posted on how it turns out and if there's a fix or update. Otherwise it's back to waiting on version 8.07 or even after that for the fix. On Second Thought that is kind of Terrifying.
Only just saw this. (on a Mac, here).
Seems to work properly here. If I switch DP to 64 bit mode, the plugs I see all change.
Good luck getting it sorted.
Swine
Post by Swine »
Awesome a reply finally. Ah bummer no help thanks though.Maybe I should make clear this is a Windows issue only as far as I know of. Once again all plugins work in 32 bit mode & in 64 bit mode only invert phase shows up. I recently added a new plugin by Eventide a channel strip & it works fine in 32 & 64 bit mode so the problem is clearly on Motu.They have it working in both modes 32 & 64 for others (plug ins) also just not all of theirs (plug ins) show up in 64 bit mode. Only invert phase show's up like I said in 64 bit mode & now my Eventide also.No others from Motu though.Still testing other plugins real limited as of now. Any suggestions on free ones that actually do their job and I'll test them against it also. Until then it's back on Motu.Come on guys get with the Program. Sorry I couldn't resist.
Sorry you haven't gotten a lot of replies but that might be because there aren't that many Windows users on a board that has been primarily a Mac-oriented board, and it may be not a lot of people are experiencing the issue. I wish I had time to mess with the Windows version, but just don't. :(
