Bounce to disk, Where is SR select?
- Timeline
It used to be there in 7. Why is it missing or is there some new option key click trick to get it to appear?
Re: Bounce to disk, Where is SR select?
What output format are you choosing?
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
- Timeline
Usually BC Wave but have tried AIFF as well.
- Dan Worley
You have to use Core (lower in the menu choices), and another window will pop up after you hit Okay in the first window.
DP10.13
- Timeline
OK will check that out. Thanks, gb
