DP 8.06 "Building overview" each time project opens
I've seen this issue discussed on the forum before...for DP 6 and 7, but my searches didn't turn up anything yet for DP 8. I've not seen this issue before now, so thought I'd post.
I've got a couple of new projects that are caught in the cycle of "Building overview" for my audio files each time the project is opened, regardless of whether or not the project was saved before being closed the previous time.
I tried doing a complete "Save a copy as..." including all audio and saving to a different folder, but the "building overview" process still happens each time. The strange thing about this is that the copied version of the project folder does NOT contain an "Analysis Files" folder and will instead update the analysis files from the original project folder each time the project opens.
Not sure if any of this is relevant, but it may be helpful to know several bits of info. about my setup and these files. There are 2 Macs involved here, both running OS 10.9.2 and DP 8.06. The project files were originally created in the field on the laptop, and were copied over to my desktop (a mini) for mixing. Both Macs are recent (within the last 3 months) converts to 10.9, and I did clean OS installs on both machines, including re-installing all programs (DP included). I don't think I've created any other new DP projects since I did the 10.9 upgrade. Not sure if that's connected in any way, but just thought I'd mention it.
Let me know if you folks have any ideas of things I should try or more information I can provide to help troubleshoot this issue. Thanks!
iMac 2017 4.2 i7, 32 GB RAM, Mac OS 10.12.6
DP 9.52
Motu 896mk3 hybrid, True Systems Precision 8, Apogee Rosetta 800
DP 9.52
Re: DP 8.06 "Building overview" each time project opens
What is happening in Console?
The only thing I'm seeing DP/MOTU related in console is the following:
Apr 14 10:45:53 "mycomputername" Digital Performer[47283]: Error loading /Library/Audio/Plug-Ins/MOTU Control Surface/CueMixMackieSurfaces.bundle/Contents/MacOS/CueMixMackieSurfaces: dlopen(/Library/Audio/Plug-Ins/MOTU Control Surface/CueMixMackieSurfaces.bundle/Contents/MacOS/CueMixMackieSurfaces, 262): no suitable image found. Did find:
/Library/Audio/Plug-Ins/MOTU Control Surface/CueMixMackieSurfaces.bundle/Contents/MacOS/CueMixMackieSurfaces: no matching architecture in universal wrapper
DP 9.52
DP 9.52
I believe I'm using the latest versions of all pertinent software.
I began earlier tonight to try and understand why DP is giving me this nasty console information upon start up and then refusing to quit properly.
10/14/14 8:26:43.223 PM Digital Performer[15410]: Error loading /Library/Audio/Plug-Ins/MOTU Control Surface/CueMixMackieSurfaces.bundle/Contents/MacOS/CueMixMackieSurfaces: dlopen(/Library/Audio/Plug-Ins/MOTU Control Surface/CueMixMackieSurfaces.bundle/Contents/MacOS/CueMixMackieSurfaces, 262): no suitable image found. Did find:
A little googling brought me here and I may see a pattern. None of the folks reporting this issue seem to be running a thunderbolt audio interface. I've using an mk828ii (firewire) with an almost new iMac. I see others are using an 8pre, which I believe uses USB 2, with their late model iMacs.
Is anyone that's using a newer iMac with a Thunderbolt audio interface getting this console message too?
I don't know but I'd be glad if I could get DP to just quit and not 'force quit.' Small thing thing that it is, it's a bit out of my comfort zone.
I had this exact issue when I updated to OS 10.9.1 from 10.9 and DP 8.06 from 8.05. Same Console messages, too. Something about CueMixMackieSurfaces.bundle makes it load incorrectly. The only difference is that, for me, DP would crash a couple of times before it would load and, when it did load correctly, CueMixMackieSurfaces.bundle didn't show up in Console–it was also greyed out in the plugins (that I never used but...).
Here's how I solved it: In System Preferences/Security & Privacy check the button that says Allow apps downloaded from: Anywhere
Reinstall DP 8.06 or 8.07. Repair Permissions in Disk Utility. Reboot. Repeat if necessary. I had to do it three times but I had other 10.9.1 problems to fix also–I'm not sure that I had changed security first.
DP 8 does not have an uninstaller. It will install over itself if you allow it. Anyway, that fixed me up. I had no problems with the OS 10.9.2-5 nor DP 8.07 updaters.
If you prefer one of the other Security settings, now you can go back and reset them.
Thanks for trying to help, Mike. I wish it had worked. I did everything you suggested. I bought a Firewire to Thunderbolt adaptor, thinking that perhaps my brainstorm last night might be right after all.
Nothing helps. Yet.
I really suspect it's one of my plugins. If I don't use the plug-in I still get the nasty console message about CueMixMackieSurface lacking a suitable image and "matching architecture in universal wrapper" but at least DP closes normally.
If I use the plug-in I must Force DP to quit. I'm planning to contact MOTU directly about this but that will have to wait until tomorrow. Maybe it's Apple? Maybe the plug-in developer? Nobody knows....
Stay tuned.
Nothing helps. Yet.
Stay tuned.
I had this problem too, but updating to DP 8.07 seems to have fixed it.
You can do a 'merge soundbites' on the whole thing and I think that fixed it for me.
But yeah, upgrading to 8.07 also seems to have helped me.
Correct. That is the solution. "Merge soundbites" is your friend. Otherwise, DP has to gooutofhand wrote:I had this problem too, but updating to DP 8.07 seems to have fixed it.
through the process of rebuilding your waveform views from the dozens, or possibly hundreds,
of punch-ins and overdub takes you did.
I don't record multiple takes of vocals. I have the singer cut the song and then punch-in
the phrases that need fixing, because often the first take contains a lot of "on-the-money"
sections that can't be re-captured. At the end of the session I do a merge soundbites on the
vocal track so I can get rid of all the little snippets of audio on that track. If I don't do this, sure enough the next time I open that project I'll get the "building overview" message.
http://www.davepolich.com
I could be mistaken, but I vaguely remember Magic Dave answering this question here before. You might want to search his posts.
BTW, is there any reason you haven't gone to 8.07?
Phil
Phil
Hmm. I did a quick search and couldn't find anything. Maybe I was mistaken.
Phil
Phil
