I'm trying to drag and drop impulses responses (as .wav files) in to proverb but I'm not having any luck. I can load factory files no problem at all. Has anyone else experienced this?
I'm using 8.1, 64 bit.
Can't load impulse responses in proverb
- (Custom built) Intel i7 4770k (3.8 GHz), 32 gb ram, Windows 8.1, DP 8.05
- 15" Macbook Pro (Intel, 2.53 GHz), 4 gb ram (slave computer)
Re: Can't load impulse responses in proverb
I have experienced this. The problem was due to a faulty bus situation. My working theory is that ProVerb needs a working input and a working output. If you try doing anything with IRs before those are established it will ignore all of it.
Now on my rig, I had a bus set up, but something was buggy in DP and the bus didn't work. I believe this is why ProVerb did this in my case.
You might also want to repair permissions. (Just a hunch, but maybe it can't write to the folder where it puts IRs).
Hope this helps.
Hope this helps.
