Hi there everybody,
I'm trying to figure out how to use Multi Bounce to speed things up, and I keep getting an odd message. I'm following the procedure in the manual, and it's not working. Here's what's happening:
1) I select a few tracks, File -> "Bounce"
2) Check "Save settings for Bounce Again", give it a name
3) Repeat this a few times so I've got a few set up.
4) Select Multi Bounce and highlight them.
5) The Multi Bounce window says "Could not open Document", and fails.
I've tried this both with the document open, and with it closed. No Dice.
It's a serious bummer, as I was hoping to take advantage of this when rendering in a large template. Any ideas out there?
Thanks,
Mike
Win 7x64
DP 8.05
EDIT: I should note that doing the bounces one at a time works, so it's just Multi Bounce that's giving me trouble. Thanks!
Multi-Bounce Error?
- Primary DAW OS: Windows
Multi-Bounce Error?
Re: Multi-Bounce Error?
You might want to give MOTU tech a call. I don't know what you might be doing wrong but they can walk you thru it.
