Does anyone know if there are plans in the near future for support of VST3? Anyone from DP HQ?
The reason for the question is because I love VE Pro and how it revolutionized the flexibility of scoring templates. I don't think I could ever go back to using my 2408's ADAT, piping a small number of audio channels. I don't know how I worked like that before.
But for those fellow VE Pro users, you probably share my frustrations with the AU limitation and having to use the Event Plugin workaround. I know this isn't DP's fault with all the bugs that come from this (i.e. - dropped notes, hanging notes, CPU freak outs, etc.) Since the Event plugin, at it's best, is a batched together workaround to make fuller use of VE Pro.
Over on the VSL forums, there are requests to make a MAS version of VE Pro.. but they say there "isn't enough user requests to make this a priority." So we can pretty much count on that never happening any time soon. which sucks.. but what can you do..
Now, recently I tried Cubase 7. I know, I know, I'm not at all condoning this, HOWEVER I spent a few days mirroring my template in Cubase. I literally used the exact MIDI routing and everything that I have setup in DP. I wanted to see what's up, so I replicated my "FULL Template" which is easily around 700+ MIDI tracks, and 100 or so audio returns/tracks. To my surprise, Cubase handled this AMAZINGLY well. as in I had the session at 256 buffer, had tons of MIDI data (to test it out) playing simultaneously and it performed perfectly. Not a single hiccup. Literally.. not ..a ..single..ONE!
This to me, confirmed that my rig is good to go. there's nothing about switchers, LAN cables, settings, preferences, hard drives, repair permissions, OS, etc. etc. nothing. The only difference is (other than a different DAW) is that i'm using it's native VST3 mode, vs AU.
Now, if I load up my "FULL Template" in DP, holy crap.. it freaks out. I have to use a paired down version that's about half the size. Even then, I have to have my session at 1024 buffer to make it so the CPU doesn't freak out all the time. However, this is with about 40 or so Event Inputs. Which, if you've researched this enough, is a big no no for stability in DP. I know.. but right now, it's the best option I can use to get a large template to work.
Sorry for the long explanation, but I wanted to explain how seemingly, just by having VST3 and by not having to have 40 Event Inputs (due to AU limitations), everything works amazingly well. Again, i'm not saying that Cubase is better or anything, in fact I don't like the workflow at all compared to DP, which is why I will always stay with DP (and I hope others do too). But I wonder if, by chance, DP incorporated VST3 functionality, would it then be the ULTIMATE DAW?!?
If I could get the same stability as I did with that Cubase trial in DP. I would be one happy camper.
Cheers!
