Does anyone know if MachFive 3.2 is supposed to work as a plug-in within DP 7.24? MachFive 3.0 worked fine, but since upgrading, MachFive 3 disappeared from DP 7.24. Since DP 7.24 is 32-bit, I tried setting MachFive 3.2 to open in 32-bit mode, but no luck.
Doug
Does MachFive 3.2 work as plug-in with DP 7.24?
Re: Does MachFive 3.2 work as plug-in with DP 7.24?
Yes. I'm using it extensively in 7.24 with no problems.
