Hello all,
I've been setting up a new (to me) MTP AV network with both a USB version and a non-USB MTP AV. The USB version is set to ports 1-8 and is the primary network box, and the non-USB version is set to ports 9-16. Both units are connected via the 'net' port on the back. I've followed the directions in the user manual, but for some reason ClockWorks on Windows doesn't see ports 9-16. An interesting item is that when I transfer MIDI data from ports 9-16, I see the 'NET' LEDs illuminate on the second box, but not the first. The same goes for any data sent from ports 1-8 - the 'NET' LEDs do not illuminate on the primary box.
Has anyone seen this issue before, and have any tips that I can poke the MTPs with to debug/fix the issue?
MTP AV USB Networking?
