10.8.5 released
Phil O
10.8.5 released
Post by Phil O »
FYI
Re: 10.8.5 released
:woohoo:
TIme to blow up the Mac!
Thanks, mon.
Re: 10.8.5 released
It's... snnnnn......
Re: 10.8.5 released
Snow Turtle? :wink:
Re: 10.8.5 released
Ha... -appier!
Phil O
Re: 10.8.5 released
Post by Phil O »
I have a partition that I use for testing upgrades. Installed 10.8.5 there. So far no problems.
Phil
Re: 10.8.5 released
I only do that when the names change.
Phil O
Re: 10.8.5 released
Post by Phil O »
To protect the innocent?
Re: 10.8.5 released
Phil O wrote:To protect the innocent?
My machine lost any hint of innocence decades ago... and my computer's been thru the bushes as well.
:band:
mhschmieder
Re: 10.8.5 released
Post by mhschmieder »
Kind of surprised to see this update -- isn't 10.9 less than a month away?
ChrisByrd
Re: 10.8.5 released
Post by ChrisByrd »
I guess this will be the final stable release for those who want to stay with ML for a while - I'm not sure I want to risk my five-year old iMac!
No problems with 10.8.5 here.
MacBook Pro 2.5Ghz Intel Core i5 4GB RAM, Mac OS X 10.9.1, Apogee Duet Firewire, Yamaha S90, Digital Performer 8.0.5, Finale 2012c, Cubase 7, Logic Pro X, NI Komplete 9, HALion 5
Re: 10.8.5 released
No problems here either. How do you know the new OS is so imminent?
Re: 10.8.5 released
mhschmieder wrote:Kind of surprised to see this update -- isn't 10.9 less than a month away?
Apple always has an update when the next release is due. 10.7.4 was about the time of 10.8 and 10.7.5 was after IIRC. 10.6.8 was so that the App Store would work for 10.7. I remember 10.4.11 being released after Leopard, too.
The major issue for 10.8.5 seemed to be large file transfers over Apple's new wi-fi standard. I happen to have an affected machine. Being one of the few who can test that, I noticed no difference - but then I didn't have a problem before the update, either. The Combo Updater was 845MB - I downloaded on my iMac and pushed it to the other four Macs in the house.
The update caused a 13G Time Machine backup on my wife's new MB Air that came with 10.8.4 last month. The backup took about 15 minutes over wi-fi -- that is just freaky to watch wireless go that fast. The other four Macs each had about a 3.4MB TM backup including overhead. Permissions were clean on all 5 machines.
Kubi
Re: 10.8.5 released
Post by Kubi »
There's another issue with 10.8.5 - the OS seems to ignore Energy Saver settings and puts non-startup drives to sleep regardless of how the Energy Saver is set.
Some people report having trouble getting the drives to spin back up. For me the drives do spin up when accessed, but it's a pain in the neck since it slows everything down, and startled me when I noticed that I kept hearing drives spin back up for no reason.
Resetting the Energy Saver prefs doesn't work. Still same problem afterwards.
Right now I'm testing the solution someone put forth on an Apple forum that not letting the display sleep actually makes the OS respect the Energy Saver setting to not let the HDs sleep. We'll see how that goes.
If that doesn't work, there's this little utility that seems to do the trick:
https://www.macupdate.com/app/mac/31158 ... e-spinning
Just a heads-up. Hope Apple fixes this soon.
Kubi
Kubilay Uner
http://kubilayuner.com
MacPro 2x2.8 GHz Quad-Core Intel Xeon, 20GB RAM; OS 10.9.5; DP9.01; MOTU 2408mk3 & MIDI Express 128 w/latest drivers
daniel.sneed
Re: 10.8.5 released
Post by daniel.sneed »
Here, energy savers have always been set to *never*, and 10.8.5 seems fine.
Falcon, Kontakt, Ozone, RX, Unisum, Michelangelo, Sparkverb, Soundtoys
