Second Instance of DP launching?
- Robb Scott
Recently, for some reason, when I launch DP (7.24) a second instance attempts to launch. The second instance shows up in the Force Quit window as "not responding". I can force quit and proceed as usual, but this is just strange. There's nothing I can say triggered it, either: no new plugs, same OS I've been using (Lion).
Anyone else ever seen this?
The One True Robb
The One True Robb
Re: Second Instance of DP launching?
I have. Can't remember, but I think there were two versions on the HD. Check for multiple versions and delete offenders.
- Robb Scott
Good guess, but nope, just the one copy. When this happens, both are v. 7.24.MIDI Life Crisis wrote:I have. Can't remember, but I think there were two versions on the HD. Check for multiple versions and delete offenders.
Another data point: This 2nd instance seems to be RE-launching itself sometime after I force quit it (and while the 1st instance of DP is running). Have only seen this once, will try to observe whatever's triggering that if/when it happens again....
The One True Robb
The One True Robb
No, bad guess. It was wrong. Sorry.
- Robb Scott
Not at all, nothing to apologize for, and sorry if that came out snarky - wasn't meant that way at all.MIDI Life Crisis wrote:No, bad guess. It was wrong. Sorry.
I think I got it: The second instance of DP happens when I turn on Apple's Software Synth in the Interapplication MIDI . I'm trying to use this for a custom click to count off a live guitar track, something I've done in the past. When I Force Quit the 2nd instance of DP, the Software Synth goes Italic. So I head over to Interapplication MIDI, turn it back on, and voila, instance 2 returns. Damn.
Wonder if this is a known bug, and I wonder if DP version 8 fixes it. Getting on time to upgrade, I guess....
The One True Robb
The One True Robb
Thanks for the update. I didn't think you were snarking at all
and I thrive on crits and insults.
Glad you found it out.
- Robb Scott
I don't like your tie....MIDI Life Crisis wrote:....I thrive on crits and insults.
The One True Robb
The One True Robb
Ha! I hardly ever wear ties but the ones I have a pretty cool.
