DP / Kontakt problem
manwalksintoabar
Post by manwalksintoabar »
I could use some help please!
DP 8.0
Kontakt 5
I am using a Focusrite USB 2 Audio Driver. When I run Kontakt 5 alone, everything works fine. My Audio settings are
DRIVER: ASIO
DEVICE: Focusrite USB 2.0 Audio Driver
DEVICE DRIVER CONFIG: ASIO Config
STATUS: Running
SAMPLE RATE: 44100
LATENCY: 133 Samples
When I use DP with Kontakt as a plugin, the configuration above doesn't work and I get this error message. . .
"DP has encountered an error. The selected audio hardware could not be found. Check that the device is connected to your computer and turned on."
This is the configuration I try to use with DP.
DRIVER: ASIO
DEVICE: ASIO4ALL
CONFIGURE DRIVER: ASIO Config
STATUS: Running
SAMPLE RATE: 44100
This setup did work a couple of weeks ago but I don't klnow what happened or changed.
The 32 bit Kontakt .dll files are in located in Program Files (86) folder. The 64 bit Kontakt .dll files are in the Program Files/VST folder.
Thanks for any help you might offer.
MWIAB
BobK
Re: DP / Kontakt problem
Post by BobK »
Wrong forum - try the troublesooting forum.
See the red box at the top of the page for forum guidelines.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
Killahurts
Post by Killahurts »
FWIW, I was having the same problem with 8.0 and K5, on the Mac side. Problem went away when I went to 8.01 or 8.02, somewhere back there.. Now I'm on 8.04 and every now and then it crashes on quit, says Kontakt is the reason. It only seems to happen on quit though, so hasn't been too big a concern for me.
Killahurts
Oh, and make sure your K5 is the latest version!
manwalksintoabar
thanks.
MWIAB
For future reference, posts that contain the word "problem" generally belong in the Troubleshooting forum-- for Windows OS as well. :) Moved.
