MIDI driver issues still.....
cloudsplitter
Post by cloudsplitter »
After the latest issue with the new drivers...and then MOTU sending us an update that apparently went back to the old drivers I'm having this weird issue. I Use a Mackie Control Universal and the faders work the faders in DP EXCEPT if a track is record enabled...I have never seen this before.....I can mouse the record enabled track fader fine but it doesn't respond to input from the mackie control. when I take record enable off then the fader responds to mackie control...very bizarre......???? Anyone else notice this...?? Mark
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
Dwetmaster
Re: MIDI driver issues still.....
Post by Dwetmaster »
My Mackie setup works as exected.
Sent from my iPad using Tapatalk HD
Agent of Random
Post by Agent of Random »
sounds strange, but I can't see how that would have anything to do with the MIDI driver...
cloudsplitter
It seems to be a MIDI communication issue or something....? It is the strangest thing I've seen. Why would having a track record enabled stop its MIDI input sensing...?
When there is some bizarre issue that some have and others don't, it's usually a driver, so you may be right that it's the MIDI driver. I'd pretty much guarantee that those who have the problem will also have the same version of driver as you, or else the same history of installing the bad one, then replacing it with another. Those who don't experience any problems probably did not update the driver, and are still using the one that has worked all along. MIDI drivers can cause some really strange problems. It's a good candidate.
It'd be worth noting what drivers you've got when you take either side of this issue.
