I create a new audio track in DP8 and name the track (ex: Dark Layering) Now when I transfer my MIDI to audio the newly generated audio track no longer has the track name as in DP6. It will show the input from the bundle and not the name I typed. Can this be corrected by a setting? I haven't found it if there is.
Hi, I'm not prepared to answer your question; I'm just trying to figure out the relationship between the two pictures. Are they related? Is "Dark Layering" related to one of the tracks in the other picture?
Sorry, I just need more explanation. I don't see any clues to connect them.
|l|OS X 10.12.6 |l| DP 10.0|l|2.4 GHz 12-Core MacPro Mid-2012|l|40GB RAM|l|Mach5.3|l|Waves 9.x|l|Altiverb|l|Ivory 2 New York Steinway |l|Wallander WIVI 2.30 Winds, Brass, Saxes|l|Garritan Aria|l|VSL 5.3.1 and VSL Pro 2.3.1 |l|Yamaha WX-5 MIDI Wind Controller|l|Roland FC-300|l|
Shooshie wrote:Hi, I'm not prepared to answer your question; I'm just trying to figure out the relationship between the two pictures. Are they related? Is "Dark Layering" related to one of the tracks in the other picture?
Shooshie, the pictures are of DP6 and DP8. I posted them to show the "Track Name" assigned to the audio file after recording from MIDI to audio. I am using a bundle to transfer the files and have noticed the track names in DP6 will relate to the name I have assigned to the track however, the track names in DP8 are assigning the bundle name instead of the assigned track name.
Dan Worley wrote:I would guess your preferences didn't transfer over to 8.04. You can set what the file names are based on from the Audio Monitor mini menu.
Exactly.
Some users seem to have trouble finding it because they expect to see these settings in the Preferences window.
--------------------------- "In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth." ― Richard Feynman
