should not be hearing anything... but
I can't seem to figure out why I can still here this. I have edge edited every track and can still here the director saying phone call dialog. I have manually edited every volume. How is this possible. Could a Waves plug-in be causing this.
I was thinking I will have to try the wave form editor but honestly that is my personal weakest link with DP. I will definitely RTFM before I delve in.
I will take any suggestions here
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
Re: should not be hearing anything... but
I cannot tell from your description. Do you have bleed through an aux?
Have you solo'd each sound bite to find the offending track?
Is there one hidden from view or off your screen?
No I have not soloed each track. yeah i guess in need to do that. No hidden tracks and have deleted the 2 Auxs I had. I still dont understand why edge editing does not do the trick
- Dan Worley
Hey, today I was trying to EQ a track and I couldn't understand why I couldn't hear any change. Ha! I was listening to the old mix. I didn't have input monitor turned on for the real-time mix track.
Sadly, it's not the first time I've done that, and it won't be the last. Sometimes I actually thought my EQ moves made things sound better while I was making them.
You'll find the problem. It's probably something simple and stupid.
DP10.13
You mention edge editing. Are you applying fades?
- doodles
Dan, this is brilliant! Done the same kind of thing so many timesDan Worley wrote:Sometimes I actually thought my EQ moves made things sound better while I was making them.![]()
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
What I was doing was removing the area in questions and edge edit to where it is good and apply the fadesmikehalloran wrote:You mention edge editing. Are you applying fades?
Had a problem like this once...deleted EVERY track and could still hear the mystery audio. Turns out it was the audio embedded in an included quicktime video. Doh!
Couple of thoughts.
Is punch guard enabled? Shouldn't matter but its a pretty new feature and might have some issues.
More likely: sometimes edit windows from inactive chunks can be visible and editable but not sounding if they are not from the active chunk (sequence).
Close ALL windows and open your edit window from the active tracks window and try again. I suspect you'll find the problem.
A quick way to check and edit is to select the region and hit opt-spacebar. That should play only the selection.
Good call on the QT!
Ok, I thought I was nuts because had every track muted and still hearing audio. Just opened the 720p mp4 file in quicktime and the dialog is there. Is there something I can do to disable or should I request another file from producer
I usually just turn the volume all the way down in the movie window.
If you have QT pro, you can take out the audio and export the file.
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
Thank you for the help
If you're using Melodyne, that's another possible source. Once transfered, Melodyne reads from it's own files on disk.
Phil
Edit: Woops, I see you found the problem. Ignore that man behind the curtain.
Phil
