MODEL12 loses its output ?
Gone To Lunch
Post by Gone To Lunch »
I'm in a track and my Model12 just spontaneously goes off every few minutes, ie it will only last about 2-3 minutes of the 4-minute track I am working on ?
All of the levels remain the same when I check them, the MIDI indicators still flash and the signal shows up in the little horizontal bar, but no sound.
If I disengage the blue circle icon and the re-engage, the signal returns, but again not long enough to finish the track....
http://gonetolunchmusic.com/
Current sex toys : DP 11.32, Mac M1 Studio OS 13.6.3 64 gb Motu M4. Sounds by VSL, Addictive Drums 2, Native Instruments, Orange Tree, Bolder Sounds. Plug-ins by PSP, VSL MIR Pro 3D, 2CAudio, Waves & Lexicon. Scores by Dorico Pro 5.4.
Dwetmaster
Re: MODEL12 loses its output ?
Post by Dwetmaster »
Yeah that's a know bug. I don't recall seeing it since DP8
Phil O
Post by Phil O »
I've seen this bug for a long time. The only solution I've found is to save, quit DP and re-launch. If you still can't get all the way through the track, then record M-12's output to an audio track until it quits. Then reset it and pick up where you left off. Continue until the audio track is complete.
There seems to be no rhyme or reason to this bug. I've had projects that work perfectly and others that can't get past 32 measures. I hope Dwet is right about it being fixed in DP8.
Phil
