Does anyone else have this problem where you open a soundbite in DP's audio editor, and everything freezes while it thinks about something. After you close the window, everything freezes again and the audio system restarts itself (same as if you change your buffer setting). On my large template projects, it seriously takes 5 minutes of beach balling and reloading kontakt instruments, VE pro connections, and then waking back up. Sometimes I open the waveform editor on accident, and just have to sit there while it tries to figure out what to do. I know that if you turn off the little PLAY ARROW button in the WF editor, it doesn't have this problem. But.... it's always on by default, and turning it off freezes things for just as long as closing the window.
Anyone know why DP has this weird behavior, and more importantly, how the hell to make it stop?
thanks!
