The conventional wisdom was always that pci was faster, more powerful and more efficient than FireWire audio interfaces in the past. (I lightpipe in from pc slaves.)
Should i wait for thunderbolt?
Dare I reconsider FireWire in this new environment?
Reconsidering FireWire interfaces
Re: Reconsidering FireWire interfaces
IMO, if you are content to use the built-in near-zero latency digital mixers incorporated in many interfaces these days, and you don't need more than 24 inputs or so, Firewire is fine.
I've been using a Firewire MOTU 828mkII for years. Coupled with an eight channel litepipe preamp module and a few additional external analog pre's, I am able to record substantial sessions (8 drum mics, plus bass, guitar and vox) with this setup. Monitoring is handled via the MOTU's built-in mixer and CueMix software. An external reverb (which is not needed with the 828kIII - it has built in 'verb) provides aural ambience.
However, if you prefer to monitor through your computer's effects, some PCI/Thunderbolt systems will provide you with a lower latency environment. Thunderbolt is essentially a PCI breakout port. With its (just hitting the marker) optical cables, Thunderbolt promises to allow very fast communication over long distances, as may be required in a studio with computer(s) located remotely from the control room.
Since we have no idea what you are running nor what you are trying to do, it's hard to say.Dare I reconsider FireWire in this new environment?
HCMarkus's advice is as good as anyone is going to give under the circumstances.
Do yourself a favor and post your hardware, OS and what you have loaded in your signature. This will help us all.
Then, when you ask such a question, tell us what you are trying to accomplish.
