DP 8 and REX 2 files--can't import...
greg328
Post by greg328 »
Anybody else having trouble drag-dropping REX 2 files into the tracks window on DP 8? Was super-simple with DP 7 and earlier. Just drag onto an empty stereo audio track.
With the new version, I can't drag-drop or import into the Soundbites window..
Any idea why? I can't seem to find a toggle preference that would disable it...
Greg
greg328
Re: DP 8 and REX 2 files--can't import...
Post by greg328 »
Bump
Agent of Random
Post by Agent of Random »
for some reason rex import only works in 32-bit mode
greg328
Post by greg328 »
A ha! Makes sense, thanks.
kinnylandrum
Post by kinnylandrum »
What a drag. Hope they fix this.
DP 10.11 MacPro 16-core 3.2 GHZ, 48 Gb Ram, 10.15.2, numerous VIs, etc.
Agent of Random
The REX library file itself is 32-bit....64-bit import does not work in logic either, which suggests to me that this is Phead's deal.
FYI only the import function itself is broken...you can import the file in 32-bit and switch to 64-bit and the file will still work
greg328
Post by greg328 »
Ok that seems like a good workaround. Thanks for the feedback. Greg
