L.A.M.E and DP8, how to make it work
Tomas E
Post by Tomas E »
I'm beginning to get a bit frustrated. I've installed L.A.M.E 3.99.5 from MacUpdate
http://www.macupdate.com/app/mac/18882/lame
I can see the LAME Audio Export: MP3 option when exporting soundbites. At MOTU's support they say:
The LAME.framework should be placed in /Library/Frameworks.
If you do not see LAME Audio Export: MP3 as a choice when you Bounce to Disk or Export Selected bites, the LAME.framework is not installed, or it is installed in the Library of another user. Relocate the LAME.framework to the global /Libary/Frameworks folder.
DP8 tells me to put it into /Library/Audio/Plug-ins/MOTU Audio Export/
Neither of them works :smash:
Here's what the installer says
What is installed where?
The following files are installed:
/usr/local/bin/lame
/usr/local/include/lame.h
/usr/local/lib/libmp3lame.0.0.0.dylib
/usr/local/lib/libmp3lame.0.dylib
/usr/local/lib/libmp3lame.a
/usr/local/lib/libmp3lame.dylib
/usr/local/man/man1/lame.1
/usr/local/share/doc/lame/html/basic.html
/usr/local/share/doc/lame/html/contributors.html
/usr/local/share/doc/lame/html/examples.html
/usr/local/share/doc/lame/html/history.html
/usr/local/share/doc/lame/html/id3.html
/usr/local/share/doc/lame/html/index.html
/usr/local/share/doc/lame/html/lame.css
/usr/local/share/doc/lame/html/modes.html
/usr/local/share/doc/lame/html/node6.html
/usr/local/share/doc/lame/html/presets.html
/usr/local/share/doc/lame/html/switchs.html
Am I supposed to move all these files into the folder MOTU Audio Export?
Tomas E
Re: L.A.M.E and DP8, how to make it work
Post by Tomas E »
Quote copied from
http://www.motunation.com/forum/viewtop ... 7&start=30
James Steele wrote:All I can tell you is it's working for me. The location is different however.
Look in this directory:
/Library/Audio/Plug-Ins/MOTU Audio Export/
You should have three files in that directory:
Core Audio Export.bundle
LAME Audio Export.bundle
libmp3lame.dylib
Since mine is working I'm posting an archive of that file here that you can unarchive and drop into that directory and it should work.
http://motunation.com/files/libmp3lame.dylib.zip
If you don't have the other files let me know, but the DP8 installer should put them there I think.
Thanks! :dance:
