There's probably an easy answer to this, but how can a guitar player hear the amp simp (I use NI's Guitar Rig) while tracking their part? Can figure out how to do this via CueMix or regular DP.
Thanks in Advance,
-Todzilla
Monitoring Amp Simps During Tracking
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
Re: Monitoring Amp Simps During Tracking
Easily done in DP. Setup menu: Configure audio system > Input monitoring mode. Set to 'monitor record-enabled tracks through effects'. Set your buffer as low as possible to reduce latency. I find 128 to be good. Read up on this in the DP 8 manual pp 218-219. Rock on!
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
Awesome, Thanks!mikeka wrote:Easily done in DP. Setup menu: Configure audio system > Input monitoring mode. Set to 'monitor record-enabled tracks through effects'. Set your buffer as low as possible to reduce latency. I find 128 to be good. Read up on this in the DP 8 manual pp 218-219. Rock on!
-Todzilla
