DP7.24 sending Controller #11 to synth modules
momsfudge59
Post by momsfudge59 »
Trying to get MIDI CC#11 through Digital Performer to synthesizers through a MTPAV. Any takers? STUMPED!!
DP MIDI Window sees MIDI Activity when pedal is stepped on. Attaches controller function to faders in the mix console just fine. Refused to pass through CC#11 to synthesizers. (No Activity Light on Synthesizer face when in record mode and pedal is stomped on)
Thanks,
Mark
Frodo
Re: DP7.24 sending Controller #11 to synth modules
Post by Frodo »
Double check that your synth is set to receive CC11, then check DP's Input Filter in the Setup menu to ensure that CC11 is not being blocked under the Controllers section in the lower half of that window.
There are ways that could go wrong in the MTP-AV. It could be filtering the CC#1 data, or it could be sending it to another cable or MIDI channel. You might open Clockworks and see if anything is set other than the defaults or the setup for your particular studio.
