Sampletank not showing up.
- twistedtom
Sampletank does not show up in the list of VI's in DP8. I down loaded the new version of Sampletank free and it said it was 64 bits at least that is what it looked like it said. I had an older version Sampletank and have a number of expansion packs for it. Sampletank instruments and samples do not import into M5-3, is there any way to do this? What about Reason samples?
Re: Sampletank not showing up.
Unless IKM issued an update, the VIs are 32 bit. Some will work using the VST versions and jBridgeM, but I couldn't get all of them working this way. The jBridgeM author said they don't work even if DP 8 is in 32 bit mode. They do work in Logic and DSP-Q, so I assumed it is a DP 8 issue, but the jBridgeM author says the crash logs point to the IKM VIs, and has reported it to IKM.
There are supposedly 64 bit version in the works.
correct ST2 is 32bit,ST3 will be 64bit.
I held off trying to load IK VI's in jbridge,
I'm waiting until they update.
Amplitube3 is already 64bit so no problems with that.
