Issue with Motu 2408 mkIII and PCI 424 card. Please help!
DJ_PILES
Post by DJ_PILES »
Hi friends! I have a problem with Motu 2408 mk3 and I know that the Motu usually has issues, but I don't find the ultimate solution yet.
I bought a Motu 2408 mk3 with PCI 424 card, and drivers cd. I switch on the Motu, and connect the FireWire cable.
Mi PC is Windows 7, processor i7, 8 RAM, motherboard Gigabyte GA-Z68P-DS3-B3.
The first issue says me: ''An error has occurred in the AudioWire driver: The AudioWire driver was not found (18)''
So I have installed the drivers from the Motu page:
Audio Interface Software
PCI-424 --------------------> (File Name: MOTUSetupAudio55333.zip
Type: driver
Date: 2012/09/11
Language: english
Version: 4.0.55333
Platform: Windows XP, Windows XP Pro, Windows Vista 32-bit, Windows Vista 64-bit, Windows 7 32-bit, Windows 7 64-bit
This installer (version 4.0.55333) installs updated drivers and software for all MOTU FireWire, USB, Hybrid, and PCI-424 audio interfaces for Windows 7, Vista, and XP. 32-bit and 64-bit systems are supported. The CueMix FX app now supports PCI-424 systems and replaces the legacy CueMix Console app. This update also contains CueMix FX support for TouchOSC. The minimum required legacy Windows versions are Vista SP2 and XP SP3. Supported MOTU products include:
2408mk3)
FireWire/USB-----------> File Name: MOTU_Audio_Installer-Win-110806.zip
Type: driver
Date: 2011/08/09
Language: english
Version: 4.0.48697
FireWire and USB Audio Driver Installer for Windows
This installer installs the current version of the FireWire and USB audio interface drivers for Windows 7, Vista, and XP. The minimum required legacy Windows versions are Windows Vista SP2 and Windows XP SP3.
Now the issue has change:
Motu Audio console > No MOTU Audio Device could be found. Make shure your motu audio device is connected, powered on, and that the drivers are installed.
Motu PCI Audio Console> No Motu Audio Devices Detected
The other devices work:
CueMix
Motu PCI SMPTE Console
>sound, video and game devices:
Motu PCI Audio (work correctly)
Motu PCI Wave Driver (work correctly)
I have tried a lot of solutions, but I have no idea which I have to do to solve this issue.
Any idea please?? I'm desperate.
Thanks to everybody. Kind Regards
Javi Piles
torrentg
Re: Issue with Motu 2408 mkIII and PCI 424 card. Please help
Post by torrentg »
You'll probably be best off by uninstalling all MOTU software normally. Reboot.
Then, go to C:\Windows\Installer and add the Authors column. Click it to put it in alphabetical order. Delete all MOTU files seen.
Open Regedit and manually search for "MOTU". Delete all keys found. Reboot, then run CCleaner to clean the old files on the machine and then again for the registry.
Now install latest MOTU driver from their website.
DJ_PILES
Post by DJ_PILES »
Ok I'm going to try right now.
Thanks for the help :)
DJ_PILES
Post by DJ_PILES »
Excuse me torrentg, in the drivers installing instructions there are two options:
FireWire and USB Audio Interface Installation
PCI-424 Card Installation
I have the FireFire cable, and the PCI card, so I must install drivers for FireWire and other drivers for PCI card??
Thanks again :)
torrentg
Post by torrentg »
Someone please correct me if I'm wrong, but I believe that there is no firewire involved when there is a MOTU card. I think it's called Audiowire instead, and thus, the firewire driver does not need to be installed. I am not sure though because I don't own this gear, so don't take it as gospel or anything. Good luck!
torrentg wrote:Someone please correct me if I'm wrong, but I believe that there is no firewire involved when there is a MOTU card. I think it's called Audiowire instead, and thus, the firewire driver does not need to be installed. I am not sure though because I don't own this gear, so don't take it as gospel or anything. Good luck!
I never installed the FW drivers for my 2408-II. Yes, its Audiowire, which is not Firewire, just uses a similar cable.
DJ_PILES
Post by DJ_PILES »
Thanks for help me!! I finally installed and it runs ok!! :)
Thanks again
torrentg
Post by torrentg »
Very glad to hear it and you're welcome!
