New Trojan can install without password
What a revoltin' development this is! Basically turn off Java if you don't need it.
http://www.macworld.com/article/1166169 ... c.rss_main
:vomit:
kgdrum
Post by kgdrum »
WOW!
Scary stuff,
2 questions:how do you turn off Java?
Are there programs we generally use that need to have Java running?
Re: New Trojan can install without password
Utilities>Java Preferences>Uncheck under General.
I don't think think this is necessary on new machines under Lion or ML.
kgdrum
Post by kgdrum »
What about Snow Leopard?
I'm running SL on my machine and it has Java installed.
kgdrum
Post by kgdrum »
So that means you can't disable?
This stuff is a bit beyond my understanding.
Check the Utilities folder for that Java preference. If the pref is there, Java is installed and you can disable it from there.
kgdrum
Post by kgdrum »
And what do we actually need Java for?
drummer jokes welcome ;-)
Java is there to run applets embedded in web pages. Personally I haven't missed it.
Looks like Apple already has a fix for this in 10.6.8 systems via software update. :woohoo:
kgdrum
Post by kgdrum »
Hi Cuttime,
Good news!
Is this a recent software update to look for?
Recent as of a couple of hours ago!
http://reviews.cnet.com/8301-13727_7-57 ... j=MacFixIt
kgdrum
Post by kgdrum »
Updated,thanks for the insight & assistance ;-)
Phil O
Post by Phil O »
I turned off Java on my Snow Leopard system with Java Preferences.app when I first heard about the vulnerabilities. After applying the update, Firefox would not launch. Turning Java on and then off again solved the problem - just a heads up for anyone using Firefox.
Phil
Here's how to yell if you are affected and what to do about it.
http://gizmodo.com/5899352/mac-flashbac ... 0-infected
If you have any of the following installed, it won't get you.
/Library/Little Snitch
/Developer/Applications/Xcode.app/Contents/MacOS/Xcode
/Applications/VirusBarrier X6.app
/Applications/iAntiVirus/iAntiVirus.app
/Applications/avast!.app
/Applications/ClamXav.app
/Applications/HTTPScoop.app
/Applications/Packet Peeper.app
If any of these are found, the malware will skip the rest of its routine and proceed to delete itself.
