Are you using Superior Drummer with Automap by any chance?
I cannot get Superior Drummer to show up in Automap as an inst.
I've selected the automap version of the AU plug-in, but Automap
still doesn't want to map Superior Drummer.
I've posted over at Toontrack and Novation, but still no responses
yet.Any suggestion would be greatly appreciated.
Sorry, Tom, I don't use Superior Drummer.
Is automap working for you with other plug-ins?
If yes you must search for the problem in S.D.
Have you tried to map manually the controller over the plugin?
Sometimes the auto-mapping function don't works in the right mode.
If you don't mind me asking, are you using a novation control surface with DP? Does it work well? Which one do you use? I'm needing to get one and I was just wondering how nicely the Novation ones play with DP. Any info would be appreciated. Thanks!
I have a Novation Zero SL MkII. Automap 4.3 maps DP mixer at launch, with the use of sliders, pots , encoders (pan) and buttons (mute and rec). It's also easy to map plug-ins with the tools of automap.
