1.Sorry for my bad English
2.Can I sample into M5 3 directly?
3.Can I automate Sample Start?
4.Is there a prelistening function, also for whole instruments?
5.Can I do round robin?
6.Can I do Voice Groups?
7.Can I randomize Pan, Velocity and Loudness with different values?
8.Finally can I reverse Samples?
I asked it because there is no Demo and I have already Kontakt.
If some things are not possible, see them as suggestions for future versions.
Are the following things possible?
Re: Are the following things possible?
2. No
3. Yes
4. for single sample, yes, not whole instruments
5. Yes
6. Yes
7. Yes. For velocity, you'll need very simple script though.
8. Yes
3. Yes
5. Yes
6. Yes
8. Yes
Not to disagree, but #1 is possible. He could be sorry for his bad English.
thank you very much for your help!
One suggestion for the developers(if they read it): please upload a manual for everybody for downloading. It is the best way to get to know it. Or some more video explainations(for example I bought Geist because of its umpteen videos where every part is explained exactly)
Is this possible in M5 3 ?
Would the arpeggiator settings be importable from a Kontakt library such as
L.A.Scoring Strings or the Acoustic Guitar library from Indiginus.com , or , the Arp settings
found in Orchestral string runs from OrchestralTools.com ?
Schweats
Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Re: Is this possible in M5 3 ?
Schweats wrote:Would the arpeggiator settings be importable from a Kontakt library such as
Schweats
Scripting is not imported at all. As the Arp is done using script in Kontakt I would say absolutely no.
