A long forgotten trick
Dwetmaster
Post by Dwetmaster »
I just remembered this trick today:
You have an audio track and you'd like to swap a soundbite for another one?
1- You bring your track's event list
2- You CTL-double-click on the soundbite's name.
3- You now get a popup with all the project's soundbite.
4- You double click on the new soundbite name you want.
5- Voila!!! you just replaced your soundbite with a new one. You're certain it's at the EXACT same place without having to fiddle with anything.
SHOOSHIE, is this Tip Sheet Material?
Phil O
Re: A long forgotten trick
Post by Phil O »
And if you use the event info window (Studio>Event Information or cntrl-e), you can do it all with single clicks. :wink:
Phil
midney
Post by midney »
...or Right-Clk on a file in the Soundites window.
GMT
Post by GMT »
In the Sequence Editor, click the soundbite you want to change, then click its name in the event info bar. A drop down window will list all soundbites. Click to choose new soundbite, then OK, or dbl clk your selection.
if it sounds good, it is good - ellington
macbook pro 2.53 4G OS 6.8 DP7.22 828mkII
Dwetmaster
Yeah thanks guys, I realized it worked in all these others areas yesterday. I'm still always trilled to learn a DP trick. :)
Dwetmaster wrote:SHOOSHIE, is this Tip Sheet Material?
Absolutinlootly!
I'll put it in there this evening. Gotta run right now, but I'll be back.
Incidentally, I fixed the links on the headers and footers of the tips sheet, so I'm actually working on it again. (It's about time, eh?)
Shoosh
I added all of the above to the tips sheet. They appear at the end of Tips Sheet post 3.
